Lets try and put all the various basic information into 1 place for easy reference (These are here for reference only, make sure you check your application before purchasing!):
Clutches
Clutchmasters: www.clutchmasters.com
Stage 1:
FX100 (Stage I)
· High performance street system
· Holding capacity 70% over stock
· Heavy-Duty reinforced pressure plate
· Hi-Leverage™ pressure ring design
· Sprung hub/cushioned disc
· Steel backed organic friction material
All Clutch Masters systems come complete with:
* Pressure Plate
* Clutch Disc
* Throw-out Bearing (when applicable)
* Pilot Bearing or Bushing (when applicable)
* Alignment Tool
Stage 2:
FX200 (Stage II)
· Extra long life street system
· Steel backed Carbon Kevlar friction material
* Pressure Plate
* Clutch Disc
* Alignment Tool
Stage 3:
FX300 (Stage III)
· Heavy-duty street & racing system
· Holding capacity 110% over stock
· Steel backed Segmented Carbon/Kevlar
* Pressure Plate
* Clutch Disc
* Alignment Tool
Stage 4:
FX400 (Stage IV)
· Ultra heavy-duty street &racing system
· Holding capacity 170% over stock
· Sprung hub/4-button
· Ceramic friction material
· SFI Approved on most race applications. All Clutch Masters systems come complete with:
* Pressure Plate
* Clutch Disc
* Alignment Tool
ACT (Advanced Clutch Technologies) www.advancedclutch.com
Stage 1:
Description: ACT CLUTCH KIT, HEAVY DUTY PRESSURE PLATE WITH PERFORMANCE STREET DISC, 20-50% MORE CLAMPING FORCE, SOFT ENGAGEMENT -- Torque Capacity 236 ft/lbs, Includes An ACT Clutch Disc, Pressure Plate, Alignment Tool, Release Bearing And A Product Information Note, Clutch Disc Features Steel Backed Linings For High Burst Strength, Great For Racing!
Stage 2:
Description: ACT CLUTCH KIT, HEAVY DUTY PRESSURE PLATE WITH 6 PAD RACE DISC, 20-50% MORE CLAMPING FORCE, FIRM ENGAGEMENT -- 200mm, Torque Capacity 303 ft/lbs, Includes An ACT Clutch Disc, Pressure Plate, Alignment Tool, Release/Pilot Bearing And A Product Information Note, Highly Resistant To Wear And Heat, Great For Racing!
Stage 3:
Description: ACT CLUTCH KIT, HEAVY DUTY PRESSURE PLATE WITH 4 PAD RACE DISC, 20-50% MORE CLAMPING FORCE, FIRM ENGAGEMENT -- Torque Capacity 303 ft/lbs, Includes An ACT Clutch Disc, Pressure Plate, Alignment Tool, Release/Pilot Bearing And A Product Information Note, Highly Resistant To Wear And Heat, Great For Racing!
XTD (www.ebay.com)
Stage 2:
This Carbon Kevlar clutch is generally used with our Street Series clutches. This disc uses the same CCI heavy duty high torque internal assembly used in our most extreme Strip clutches. We then add our unique woven Carbon Kevlar, steel back frictions for maximum added burst strength and thermal dissipation. This is the ultimate Street clutch. This XTD Stage 2 Clutch Kit Includes XTD Heavy-duty Pressure plate,XTD Carbon Kevlar Steel-back Street Disc, Throw out Bearing,Alignment Tool,clutch installation and XTD clutch Logo window decal.This XTD Pressure plate Holds 25% more HP and Torque Than Stock Pressure Plate and This Pressure plate is made from ductile iron and heat Treated Which is about 20% Stronger Than Just Stock Cast Iron Pressure plate. XTD Stage 2 clutch is Designed for Smooth Engagement,quiet operation and improved durability using only the best Kevlar, spring center designs.This XTD Stage 2 clutch kit is Works Great for Just Stock and Mildly Modified application.Every XTD Sports clutch kit Designed for Street (Daily driving) so It won't make you difficulty on Everyday Normal driving.All XTD Racing Clutch Kit Required 500Miles Break-in Period.
Stage 3:
XTD 6 puck "MIBA" Copper Ceramic clutch is designed for the serious enthusiast with just Stock to considerable modifications.("Miba" Copper Ceramic Material is well known for AirCraft brake material.It is more Durable and hold 60% more Torque capacity than Cabontic or Kevlar Material also "MIBA" Disc grips 30% harder than Cabontic Disc) This disc features 12 high-coefficient ceramic pads for quick engagement and the extreme duty friction needed. Our specifically designed high torque disc delivers maximum holding capacity without compromise. The sprung retainer assembly boasts 6 dual springs and 6 severe duty retainer rivets, ensuring power and reliability .This XTD Stage 3 clutch kit fits 2003-2006 Hyundai Tiburon 2.7L (5 Speed and 6 Speed).This XTD Stage 3 Clutch Kit Includes XTD High Clamp Long Life Pressure plate,XTD "MIBA" 6 Puck Copper Ceramic Disc, Throw out Bearing,Pilot Bearing,Alignment Tool,XTD Clutch Installation Guide and XTD Logo Window decal.This XTD Pressure plate Holds 30% more HP and Torque Than Stock Pressure Plate and This Pressure plate is made from ductile iron and heat Treated Which is about 30 to 40% Stronger Than Just Stock Cast Iron Pressure plate. XTD "MIBA" Stage 3 Copper Ceramic Disc is designed for Ultra Racing Purpose and it Graps Much Harder Than Carbontic or Kevlar Disc also It will Increased Acceleration.However,It designed also Smooth Engagement and improved durability for Street so It won't make you difficulty on Daily Driving.This XTD Stage 3 clutch kit is Suitable for Just Stock to Modified Tiburon.All XTD Racing Clutch kit Requied 500Miles Break-in Period.
Centerforce http://www.centerforce.com/
Stage 1:
CENTERFORCE II CLUTCH KIT -- Contains Pressure Plate And Clutch DISC Only, 60% Greater Holding Capacity, Great For Street Strip Use, Stock Pedal Feel, Great For Towing and Off Road Use, Throw Out Bearing Sold Separately, Size Metric 215, Size Inches 8-1/2, Spline 7/8"-20
Stage 2:
CENTERFORCE DUAL FRICTION CLUTCH KIT -- Contains Pressure Plate and Clutch DISC Only, 90% Greater Holding Capacity, For High Horsepower & Torque, Also Good for 4 Wheel Drive Vehicles, Size Metric 215, Size Inches 8-1/2, Spline 7/8"-20
Fidanza Clutch: www.fidanza.com
Stage 1:
Combine carbon and Kevlar, give them a steel backing and you have the most durable and longest lasting street clutch available. We’ve engineered our torsion damper and marcel cushion to engage smoothly yet quickly. Perfect for the daily drivers. We recommend this disc to those who drive their vehicle every day, in all conditions.
Stage 2:
Like our lightweight flywheels we choose to use the very best in materials. That’s why we designed our Three Point Two with the Kevlar buttons. With 100% Kevlar friction you get more grip and more life than the Two Point One. However, since it has no marcel (cushion) this disc sacrifices a little bit of its smooth engagement. Still, this disc can be installed on a daily driver. Just behave and be patient during it’s 500 mile break-in period. Once that’s over you can be as nasty as you want.
Stage 3:
This is one mean clutch. Your footwork better be good, it’s no walk in the park. Just because it has a torsion damper like the Three Point Two doesn’t mean it drives like it. Those are ceramic buttons attached to that puck. They provide quite a grip upon engagement. That means power is planted straight to the pavement. Don’t be scared though, it’s not going to give you a larger left leg.
Stage 4:
If you choose Five Point Four you’re either building an all out race car or a rocket. This disc will show you what grip really feels like. As you can see there is no torsion damper, no marcel, and the pads are made from sintered iron. What you’ll feel – instantaneous power. This is for the racers.
Clutches
Stage 1:
FX100 (Stage I)
* Pressure Plate
* Clutch Disc
* Alignment Tool
Stage 2:
FX200 (Stage II)
* Pressure Plate
* Clutch Disc
* Alignment Tool
Stage 3:
FX300 (Stage III)
* Pressure Plate
* Clutch Disc
* Alignment Tool
Stage 4:
FX400 (Stage IV)
* Pressure Plate
* Clutch Disc
* Alignment Tool
Stage 1:
Stage 2:
Stage 3:
XTD (www.ebay.com)
Stage 2:
Stage 3:
Stage 1:
Stage 2:
Stage 1:
Stage 2:
Stage 3:
Stage 4:
