21 - 40 of 54 Posts
Discussion starter · #21 ·
bms231 said:
is that the right part number? i search for it on the parts site, and got nothing.
You can do a search for "Plate" Because it is called a plate window and not bezel and it does not like "plate window" together. If you put your VIN in at the top it will have every part you car is supposed to have then under electronics there you will find the cluster, click on the picure. if everything works you should have a complete list of the cluster on the left and a exploded picture on the right. The site is hard to figure out, it took me awhile. :3_confuse
Discussion starter · #22 · (Edited)
fixer said:
no it doesnt work. a buddy and I found that about a year and a half ago.. he drove for a while and the #'s never changed....
and i dont know about it on ALL MT tibs.. the one we found it on was an realy 03..released in 02. His was so early that the steering wheel locks in a different place...
Yeah mine was manufactured in Feb. 02. Maybe Rick@real can reprogram this or something. I will ask at the dealer if they know anything about it when I get my car fixed.
your wheel locks...mine doesnt? :3_headsha :3_confuse
Discussion starter · #25 ·
I have to turn my wheel almost 90 degrees to get mine to lock.
Solo2Tib said:
Sooo, does it actually work?
I know fixer said it didn't, but maybe yours does?
alright, i didn't read all of this, i just wanted to say: I have that, it has many other options too. Km's till empty, driving time, and other 2 i think that i can't remember. BUT also, i'm in canada, so i don't know about the US models, and i'm not even sure about other, lower models, i've got the tuscani model....
oh yeah, just read the other posts. it DOES show driving style, for example, when i hit the I-5 it would read 770 or so kms pre tank. When i'm in town, its around 400 something...it'll fluxuate for example some bad short trips will make my fill-up at the station show like 300km on a full tank, then as i drive it'll count upwards, to adapt correctly...any ways...it does adapt. Stops counting after about 60 kms i think...but you can't change style to bring the counter back up, after it shows "---" its done, head to the gas station....
Discussion starter · #29 · (Edited)
Does anybody have the other push thing like the trip reset button but on the right? I noticed that there is a place on the electronics board for something. and what does it do?
Does yours have that button?
2bit said:
Baddog, this was on your Tib also? If you were to just cut or dremel the stock bezel, how much is needed to cut out? (how much bigger do you make it?)
$22 for the auto bezel? I don't think that sounds right knowing Hyundai pricing is high for stuff.
I just eyballed it. It looks like about 3/16 or so. Hopefully the numbers will work on mine. Or ill have to get a new bezel.
I looked in my parts and collision catalog, and they list 1 cover, but 2 different clusters. One for auto and one manual.
Ok so the number isnt changing or what lol that is crazy give me a couple days and ill check out that ****....Have u drove it and looked to see if the goes down or no im realllllly tired so i couldnt look through it all but i gotta work...thanks man u saids urs is an auto right. US SPEC?
Stevis50 said:
I have an auto (GT, 04), and I only have one button.
To switch between A and B you click it once, to reset it, you hold it in for a few seconds.
oh yeah, you're right. I'm dumb. I was thinking of my parent's Sonata that has 2 buttons
The 06' I test drove before getting my 05' had the Man to the Gas Pump and it was working. Also, the car was automatic that I test drove.
21 - 40 of 54 Posts
