1 - 16 of 16 Posts
Matty10501
· Registered
Discussion starter · #1 ·
So my 03 clutch is slipping what else is new, and I need to get new clutch and flywheel, Im looking to put a performace clutch in it, whats a good performance clutch and fly wheel, that can handle some abuse, I live in canada so has to be somewhere that wont charge an arm & leg for shipping. And roughly what do they cost?
I'm gonna have to do this search some time soon due to me needing a clutch soon =/ i think at 30,000 miles and about 25 passes at the drag strip, it will start slippin very soon =/
Yeah mine started slipping but didnt actually give out all together until 10k miles later.
700$ :( hows it work good? do they last long?
Works flawless, i absolutely love it! Drives like a new car. I bought that clutch used so new it will cost you around $800 or so altogether.
Hey,
I recommend going with the SPEC Clutch and Fidanza Flywheel combo. We've had great success with this setup and no problems. With the Aluminum flywheel, you might get some chatter in the transmission (normal for lightweight flywheel). Otherwise you could go with the ARK Chromoly flywheel, which will give you no chatter (but its heavier). Regardless, we sell both of them. PM me your address in Canada and I'll get you a shipping quote.
Thanks,
Kevin
KJB Motorsports
whats a trsmission chatter?? i speak french and i never heard about this workd before :(
stage 2 clutchmasters with fidanza flywheel would be good
Stay away from southbend clutch..... eeevvviiiillll
What's wrong with South Bend? Mine works fine, and it's a DD. Been to the track, MANY dyno runs, as far as power, check my sig.
1 - 16 of 16 Posts
