Here gose I have 2004 V6 Tib that has now died completely and will not start.
It was having and intermittent starring problem, if you turned the key on and the check engine light was light you could crank it and it would start and run fine for minutes or maybe days.
Now no check engine light when key on crank with no start.
I inspected the CPS it did not look new so I replaced it with an OEM part no change.
No power to injection or snsr fuse ??
So a bunch of sensors have no ect ect
Jump the main power relay get power to the fuses but no crank.
What controls that main power relay?
Any thought about what could be causing this issue??
Thanks Steve
Thanks Steve
