21 - 40 of 40 Posts
Re: DIY: AEM F/IC installation and extras
wait screw? or bolt? I dont see where there is a screw in this picture. That bolt shouldnt be to hard get to it look like lol
wat
which wire are you talking about?
well its harder for a guy my size to even get into the space under there let alone snap a pic lol...sorry man...im not worried aboutthat screw anymore..the worse that can happen is break the screw thats in there and im not worried about that much...my bigger concern now is that one wire i cut
OOOOHHH lol do you know how to solder? and have you just cut one wire?
you mean the ECU wiring harness? All of those are pretty important lol...
Zaion pm me i've got several layinga round let me know what u have installed or what u need the base map for
Sadly, i got it running and even had a rough tune
But now, after placing everything A/C related back in, car wont even start. Dismounted everything to see if i pulled something and everything look alright, and it still wont start. Gonna take next week to recheck every cable.
I'm really stumped though. It went from running fine, to starting up every 3rd crank and shutting off, to not starting at all :/
If you have an 03, the setups are different than above.
1.) the screws on the sides that are right by the cabin filter cover are not screws but instead clips.
2.) the clip on the backside of the housing is not in the same location as shown above. I have not found the exact location of them, but i know for a fact it is not where it says it is above. My guess is may be one or all of the tabs as seen below:
^^^ Turns out, those three spots I have circled above are tabs that are connected to the housing itself. I'll take a picture of it when I have the housing fully out. I dont not know of any way of successfully getting the housing out without damaging it. Mine it pretty jacked now but im not worried as I dont have ac and wont be driving this during the winter. Plus I think I can repair it (hopefully) Pending pics
Behold, Hyundai's genius at work. It's not wonder that the OP's setup is different. To get the housing off for 03's, there are three tabs that need to be pushed back to unclip from the top of the housing. To unclip them, you would need to push them towards the rear of the car, aka you cannot push through the seam from where the cabin filter sits. You would need to take out the firewall in order to properly remove them easily. Unless you removed the entire dash removed the top of the housing first...maybe. Basically Hyundai did a dumbass idea and realized it, and now the newer tibs are "slightly" easier to remove it.
f*** you hyundai
sweet DIY man keep it up
So this image says to connect:
Top O2 on Bank 1 to B13 then the Bank 1 Output on the FIC to Analog A Input?
Then the same thing with the top Bank 2 O2 except P15->B11 then Bank 2 Output to Analog A Output?
Why isn't Bank 2 Output going to an Analog INPUT instead of output->output?
There IS another Analog Input wire..
Also, for what would the Aux wire be used for?
Thanks.
Thanks.
Actually, there isn't even any O2 Output wires..
There is O21 + and O22 +
so bank 1 is to O21+ and bank 2 is to O22+, then what?
Could I get some help preeeeettttyyy pllleeeaaassseee! :(
Diagram applys to 07 to right..?
Bump...................
Discussion starter · #38 ·
if anybody is needing help text or email me... i don't get on newtib too much anymore since my old tib has become a lawn ornament... it won't sell and i have a new project ^_^
615 seven eight five 4788
From AEMELECTRONICS
"Does your vehicle have both a MAP Sensor and a MAF Sensor? Or do you want to
remap another analog signal on your car?
If so, connect the “Analog A/B” wires as shown below in Figure 10. If not, remove
the unused wires for “Analog A/B”.
SIGNAL (+)---------(Analog IN)AEM FIC(Analog OUT)----------ECU
GND-----------------------------------------------------------------ECU
VREF----------------------------------------------------------------ECU
Figure 10: Analog A/B connection
21 - 40 of 40 Posts
