Check engine P0031
2.6K views 3 replies 2 participants last post by  bblackmoor
I installed headers this week. Although everything is hooked up and the car runs fine (I put 130 miles on it today), I have a Check Engine light and an error code of P0031. I have no other errors (yet).
From my reading and searching here, I have found the following information:
P0031 Heated oxygen sensor (HO2S) 1, bank 1, heater control – circuit low Wiring short to ground, HO2S, ECM
Possible causes:
1. Related fuse is blown or missing
2. Open or short to ground in power supply or control harness
3. Contact resistance in connectors
4. Faulty oxygen sensor​
Here are my questions:
  1. I have four O2 sensors: two front, and two back. What is "bank 1"?
  2. Assuming that I know which sensors belong to bank 1, how do I determine which of the two O2 sensors is causing the error?
  3. Assuming that I determine which sensor is causing the error, how do I determine whether the sensor is bad, or if it is a fuse or something?
Thank you for your assistance.
I believe bank 1 is passenger side, sensor 1 is the one nearest the front of the car. You can test the sensor with a propane torch (when it is out of the car), but I can't remember the exact numbers/sequence. If you search, you should be able to find them.
#3 · (Edited)
That's the easiest one to get to, fortunately. I just double-checked and made sure it was plugged in.
Where would I find its fuse?
Also, I have read that the Tiburon is extremely finicky about its O2 sensors, and will throw errors if common aftermarket O2 sensors are used. If I do need to buy a new sensor, what sensor should I buy?
