Hey all, Was thinking of doing an ECU reset. Have any of you done this? for what reasons? came across this online, talking about how to reset Hyundai's is this correct for the Tiburon? thanks
Firstly bring the car to normal operating temperature by driving for 15 minutes or so.
Now open the bonnet and disconnect the earth lead from the battery, ensure this is not touching any part of the bodywork - insulate if necessary - and wait 5 minutes.
Next depress the foot brake for 20 seconds - this will completely discharge the ECU's capacitors via the brake lights.
The next step (to be carried out immediately, while the engine is still warmed-up) is to carefully re-connect the battery earth lead, close the bonnet and now drive the car in a spirited fashion (accelerating rapidly through the gears, full-throttle straights etc. etc.) for a full 30 minutes. Try to choose a quiet time on the roads for this, (i.e. early on a Sunday morning!).
This period of driving will `re-educate` your ECU into adopting more aggressive timing curves and alter the fuelling to match. It will also allow the unit to recognise any modifications you have made and to react accordingly.
If, on the other hand, you are not interested in outright performance, but are more concerned with economy and flexibility, use your normal driving style during this 30-minute run!.
