I have a 2003 Tiburon GT with just over 100k miles. Completely stock besides a cold air intake.
The problem I have started a few weeks ago and gradually got worse. It's to the point where I cant confidently take it out anywhere. I've searched the forum and haven't found a thread that discusses the issue i'm having. This is my first post.
The car starts perfectly... every time. Even when I've let it sit in the cold for long periods of time it has never had an issue starting. While in park, the idle is low (below 1k) and jumps around. As soon as I put it into gear, the RPMs go even lower to the point that I fear the car will die (it hasn't yet). It gets a bit better when I am moving. When i drive it around the neighborhood to test things out it seems to run ok. However, when i pull up to a stop sign the idle drops below 1k and the car sort of shakes and acts like it may stall out. I've noticed there is also now a smell of unburnt fuel. Recently I've noticed there is a backfire coming from the intake area during acceleration (this did not happen before).
I took it to a shop for diagnosis and they told me it threw a MAF code and a misfire code for cylinder 3. They told me they would start by replacing the MAF and the spark plugs/wires. I did both those things and the car is still running like crap. Seems like the problem got worse rather than better.
There is no CEL and the shop told me the MAF and misfire codes were the only ones that came about during the diagnostic test. I ordered an ignition coil pack and i'm going to install tomorrow. Wondering if anyone has had a similar issue? Or if anyone sees something obvious that i'm missing?
