Hello tiburon community,
Well for starters i am the owner of two tiburons, one being a 2006 beta and the other a 2005 delta.
in the few past weeks i have pulled the motor out of the 2005 to do the swap on the 2006. i have also removed the ac from the delta and have also removed all harnesses from the 2005 and ecu fuse box under the hood and dashboard, power steering and fuel lines under the hood. i did all this in my free time at work until i had the2006 there and i started pulling everything from it to swap over. the swap went excellent i took my time and managed to have it done in 48 hours on a weekend we were closed....... :websta:
so here is the issue after everything is in and before i put the dashboard back in i want to test and see if the motor will turn over.... and there is nothing but some relays clicking in the fuse box under the dash and the ignition light (green ring around key slot) is going off when the key is in the run position. i have power at the starter and everywhere else that is needed and ground everywhere else. so im officially stumped..... i have no ideas other than the factory alarm system is preventing me for some reason..... even swapped the lock cylinders thinking that the vehicle couldnt recognize the 2006 key and still the same outcome :diaf:
So summing this up ( I know this is a lot to take in ) I need help and plenty of it so im open to opinions, ideas, anything I could of possibly missed. im a well season mechanic and can do anything but electrical is somewhat of my weak spot.
please reply!
Thanks again!!!
please reply!
Thanks again!!!
