1 - 2 of 2 Posts
Cbilly64
· Registered
Discussion starter · #1 ·
I was driving this morning and when I took a right I felt it was a lot harder to turn so I went home looked under the car and power steering fluid is spraying out of this small black rubber hose when I turn the wheel can’t even drive because it comes out so fast I took it off it’s located on the passenger side it’s Right behind the wheel hub assembly near the tie rod boot looked up the number on the hose and I came find anything if anyone could help it’s connected to the return hose on the power steering pump about 3-4 inches long but there’s a tiny hole in it so it needs to be replaced any help would be great
Looks like it's missing a spring clamp. A small worm drive\radiator clamp may work. You can see the indentations from the clamp on it.
1 - 2 of 2 Posts
