Confused about what size engine i have lol
4.1K views 20 replies 11 participants last post by  krazymikeyXJ
Was wondering where do i locate my engine number thingy to find out what size it is? When i bought my car the dealer said it was 2.0 litre, however my car has a sx badge on the back and i know they came with a 1.8 litre.....they sold it saying it was a 98 but says built may 97 on the car plate under the hood. Much noticeable power difference between a 1.8 and a 2.0 anyway? iam guessing its a 1.8 and the dealer didn't know **** lol but iam not too fussed about this, just curious.
Here in the US, there is an emissions label under the hood. It states the model year & engine size. Not sure what other countries do though.
I believe your "VIN" is similar to the US version, thus you can look it up online to see engine size.
Or post some pics of the engine---we may be able to tell just by looking at it.
#10 · (Edited)
Don't answer if you don't have the right info...
The 1.8 DOHC 16V was the first engine to show up in Tiburons. There are very minor differences in the two when looking however the inside of the engine is composed of different parts...shorter rods, crowned Pistons, hydraulic lifters, shorter valves, smaller diameter intake ports, counter weights on the crankshaft.
There is no usually in this matter.
I don't know where markings can be found on the engine itself, I had a head that was stamped 1.8/2.0 which came from a Beta I.
What does that plate on the firewall say?
Keep in mind guys, the question relates to an Aussie Tib, not a North American Tib. What they get can be a lot different from what we get.
I can't answer the original question, I just made suggestions (earlier) where the info may be found.
Hmm, I can't tell for sure. It does look like the 2.0 I used to have, but as mentioned the 1.8 and 2.0 are the same block but with a slightly different piston size.
I'd also be interested to see what that plate on the firewall says, or if you can find the stampings on the block somewhere.
According to KBB and Wikipedia, 1997 was the last year the 1.8L was offered for the tiburon. So if yours is 1998, it should be a 2.0L. Although, as Charlie mentioned, the Australian version might be different. But i'd say its likely you have the 2 liter
this seems to be a tough question for everyone to answer lol. everyones in debate between 2.0 and 1.8.
being a hyundai dealer i can verify that it is a 98. just as treftz40 said.
as for the 2.0 1.8 situation, google will probably be the best of our knowledge until we get a look inside.
Thanks for all the help and information guys :D much appreciated .
Question- lets say you drove a 1.8 then a 2.0 would you be able to feel a huge power difference? Would a 2.0 version whoop ass on the 1.8? lol
Well according to Wikipedia the 1.8 was rated at 130 HP and 126 lb/ft while the 2.0 is 140 HP and 133 lb/ft
So no, you would likely not notice much difference at all.
