I have had a CEL for lean combustion intermittently sice I installed my eBay CAI. (The style that does suck in cold air from between the bumper and the wheel well) In the meantime I have also added an ARK cat back. My mechanic confirmed that I don't have any vacuum leaks, and told me that it is most likely that the CAI is letting in so much air, that the ECU is maxing out it's parameters to compensate with fuel. He said it's running very lean at high RPM and throttle, which is bad for the engine as it causes high combustion temps.
We confirmed the cause by reinstalling the OEM intake, which brought the fuel trims back to normal.
So, my question is this: Do I really need a tune just for a cold air intake?! I've never heard of this on any car, and I am seeing others say even a stage 1 supercharger can be used without a tune! I was a little worried I might need one if I decide to do headers but this is ridiculous. I don't intend to make big numbers with this car, I just want it to handle well and sound good. But even with the ARK cat-back, it's quiet as a church mouse with a stock intake and exhaust manifold.
If I do need a tune, is there some way of doing a cheap and easy A/F ratio only tune that doesn't require an actual reprogramming or replacing of the ECU? Seems like I am seeing mention of the sort in these forums but I can't find it explained anywhere simply enough for a Tune-noobie like myself to understand. I have 0 experience and knowledge with real engine tuning, since I've only done bolt-ons with no engine management issues until now.
Sorry for the long post, any help is much appreciated 🙏
