people w/ cm stg 4 cluch need info. just installed
1.3K views 10 replies 5 participants last post by  Lessaj
people w/ cm stg 4 clutch need info. just installed
I just installed my clutchmasters fx400 six puck dampened clutch w/ cm light flywheel. Is it normal for the clutch pedal to feel lighter then stock and for the clutch pedal to grabs very high up?
Ahhhh I was hoping for a stiffer pedal and a shorter pedal engagement but guess I just have to deal with it, anyways the clutch grabs nice and not that bad to drive for daily car.
The slave cylinder mod was done b4 but didnt replace the hydraulic hose to ss.
Also I would bleed the lines.
I think its how the pressure plate is but ill try bleeding it anyways.
You can adjust the pedal to change the engagement point. When I installed my twin disk I changed the engagement point to just off the floor, because any further than that was putting too much pressure on the release fork and the top of it snapped off.
How do I adjust the engagement?
I might have thought about it wrong in my head, but glad you got it!
