TurboCharging G4GC KIA Sportage SUV AUTO 268FWHP
This is a Australian Kia sportage Auto project that we just finished recently. This project was aimed at making the maximum power and troque out of the factory engine, which only has 73fwkws / 115Mn torque (0~100 in 13secs, very slow).
This KIA shares the same engine and transmission as the Australian delivered 2L I4 Tiburion and lots of the information did came in from this forum.
It is currently running on:
Brae auto: low mount manifold, and custom 3 inches turbo back exhaust,
Return flow front mount cooler:
HyperGear ATR28SS15 billet turbocharger and 50mm External gate
Ebay Auto transmission cooler
Datschwerks 650cc injectors:
Adaptronic E420D ecu:
The most that we could manage to squeeze out of the stock 4G4C engine was 200fwkws running E85 fuel in stock Auto at 13psi of boost. The high comp engine's not been able to take any more timing or boost at this point. I believe manual would be making a little bit more power.
As for the turbocharger we ended up routing an 50mm external gate plumbed back in attempt to drop EGT in and squeeze in 2 degrees of extra timing.
Engine bay:
The turbo kit:
Turbokit on:
Finished:
As for the final result we've trailed in P95, P98 and E85 fuel.
The motor's only taken 4 degrees of timing using pump 95
7 degrees in pump 98:
and 13 degrees in E85:
The corresponding HP and torque out puts are:
Maximum boost level of 13psi:
To squeeze out any more power would require lowering of engine compression which I'm thinking of two head gaskets with a 1.5mm metal plate in the center, and it also require much stronger coil packs. The standard item started to break down any thing above 14psi.
Overall the Kia is pretty good, suppressingly the engine managed fine with turbocharger, and the factory auto transmission handled 465MN of torque. Standard fuel pump is an walbro item and that worked fine even with E85.
Big difference looking back to see where we started and where it is now:
All power and torque figures are tripled. This is now a very fast KIA SUV that can beat many standard sport cars on the road.
Engine bay:
The turbo kit:
Turbokit on:
Finished:
