Grinding noise taken care of, it was just a wire loom playing with my radiator fan. :]
And an interesting development today:
I was zipping up and down the main road near my house tuning in my fuel when all of a sudden the car completely lost power for a split second. I backed off the throttle and eased it up the road. A little bit later it was running terribly. My A/Fs started swinging all over the place from 10 to 16 and ****. So I went to the SAFC2 to look at the sensor check menu and the MAF voltage was dancing from 0.something all the way up to 2.something.
At this point I was pulling into a gas station and the car was trying it's hardest to stay on. Driving at this point was useless. Due to the readings I got from the AF and from the SAFC2, I decided to unplug the MAF and try limping home. This got me home, although still running terribly. I parked in the garage and took the truck to work.
I called around to find an MAF that I could have my GF go pick up while I was at work. The only one available was a remanufactured unit from autozone. After looking at it, it's the type with the resistors inside the unit on the little wires. Hopefully this won't cause any problems. I'm about to go install it in a minute and hoping that this is the problem.
I also broke off one side of the plastic that aims the air into the MAF while installing it because Duffer's tubes were a little too long. That coupled with the questionable condition it used to be in (I've had intermittent power loss issues for a looong time) could possibly explain why I wasn't able to dial in the injectors properly like I was able to before the turbo install and what happened today.
Off to the garage..
Phoebus, definitely! I made it to one of the RK meets over the summer and found a few tibs to park next to. If you were there, I was the guy in the slammed silver tib who didn't say anything to anybody or introduce myself at all. :] I also didn't have much to show off, I just came to look. Next season!
EDIT: Reset ECU, installed new MAF, set low and high fuel trims to -35% across the board before turning on the car. The MAF seemed to have everything fixed at idle. I mean, at least it was idling. Still around the 10-11 for some reason... I let the car warm all the way up and then went for a very tame walk around the block. It ran just fine for about five minutes and then my AFs started dancing around from 9 to 16. Right when I saw this happen I backed off the throttle and it stopped. I sat for a minute and the idle began to dip around 500 and the car would almost turn off and then it bounced right back up. When it reached the bottom of it's dip, the gauge cluster lights flicked off for a second. This is pretty much what was happening earlier today. Sound like an alternator? If so why would this affect my AFs? Input/help please! I'm not sure what this is. I'm done outside for tonight, time for research.
This is the first I've looked at this thread. Oh, boy.
A lot of us have thoroughly explained the dangers of tuning this kind of setup with the SAFC2, and you're about to find out what happens first-hand. Thankfully, engines are pretty cheap. I'm sorry man, but it is what it is.
That being said, do you have access to a scan tool with live data display? You really need the ability to see what's going on there in order to diagnose the problem...otherwise you're flying blind. My guess is it's something to do with the MAF or it's position in the charge piping. Have you tried running it with the turbo disconnected from the MAF yet?
My experience with these cars has been that the ECU freaks out if it sees values it doesn't like. If you have STFTs that are way out of whack like that, the car will do all kinds of crazy random things as a result. I can't explain it, but I've seen it more than once. STFTs should be no greater than +/- 3%.
I would not recommend taking the car to Hyundai under any circumstances, but that's just me. They're just 'parts-replacers', and they're not going to have a clue to do with your car once they see the mods.
On my original setup, I ran my SAFC2 at -50% on the low throttle setting, and somewhere in the area of -10-15% on the high throttle setting. I also had 290s at that time.
I know you're excited to figure out your new setup. But the fact that you have an AFR that low at idle is an indication that something is very wrong, and I would not drive it that way at all- especially with a turbo and fragile stock pistons.
I saw you that day at RK. You should have hung around for awhile. Nobody would have cared if you didn't have anything to show off.
